£5.75 – £11.50Price range: £5.75 through £11.50
The rubber stamp “Multi” is suitable for the identification of all surfaces, especially when the use of oil-based inks is required.
The marking of surfaces with oil-based inks is particularly recommended because, where the surface of the humidity.
The oil-based inks are also available for the identification of concrete and metal to protect surfaces with a high absorption / absorption and advantageous everywhere where the marking should be light- and weather-resistant.
Here are some:
height Resistance, perfectly smooth surface, temperature resistance, low dust emission in machining
Oil resistance (the gum swells upon contact with oil-based inks not on), alcohol resistance
suitable for single and multi-colored Stempe, excellent engraving and imprint quality
210mm x 150mm, 210mm x 297mm
